tekmenlos
Apr 6, 2006, 1:02 AM
Post #3 of 3
(3218 views)
Re: [jackhamme] mitsubishi VS-60705 roll
Guess what I found? If you have lines rolling up in the picture check C2P08 100 UFD 16 V off PIN 3 off IC2P03 (3.2 Volt Regulator). These are on the Signal PCB. If you have a dark unstable raster check C2P05 100 UFD 16 V off PIN 3 off IC2P01 (9-Volt Regulator). These are on the Signal PCB. If you have flicker in video on bright scenes check C2V29 22 UFD 16 V off PIN 29 off IC2V00, these are on the Signal PCB. If you have no luminance check for open L2C50 part # 325C146030 on the Signal PCB. If you have vertical jitter check for C2P05 100 UFD 16 V off PIN 3 off IC2P01 and IC2P01 part # 270P466020 (9-Volt Regulator). You guessed right, on the Signal PCB. If you have poor vertical sync, like vertical rolling, vertical blanking bar locking in the middle of the picture and or maybe a horizontal pulling or tearing check for C2C52 10 UFD 50 V off the base of Q2C51 on the Signal PCB. Also check C2P05 100 UFD 16 V off PIN 3 off IC2P01 part # 270P466020 (9-volt regulator). Yes, on the Signal PCB. Well, hope this helps. ...Lates...
