mitsubishi vs6017r
mommyhutchison
May 31, 2005, 11:15 PM
Post #1 of 7 (2580 views)
mitsubishi vs6017r Can't Post
tv worked fine last night. turned it on this morning no picture just green horizontal line. the red and blue projectors dont come on. any ideas on how to fix it without costing a fortune?
Johnnyice
Jun 1, 2005, 8:17 PM
Post #2 of 7 (2567 views)
Re: [mommyhutchison] mitsubishi vs6017r [In reply to] Can't Post
What's a fortune in your opinion?Cool
dpalmer76
Jun 1, 2005, 9:20 PM
Post #3 of 7 (2565 views)
CHECK PIN 3 OF "AJ" CONNECTOR (9V LINE) FOR INTERMITTENT CONNECTION TO SIGNAL BOARD. LOCATED ON PCB-VIDEO. 2. CHECK IC701 (12 V REG) ON THE SIGNAL PCB 3. CHECK IC401 PIN 8 FOR 27 VDC, IF MISSING CHECK R540 1.2 OHM 1/2 W. IF OPEN IC401 MAY BE SHORTED. BOTH ARE ON THE MAIN PCB.
kengcad
Jun 3, 2005, 3:16 PM
Post #4 of 7 (2557 views)
Re: [dpalmer76] mitsubishi vs6017r [In reply to] Can't Post
Im having the same problem on a mitsubishi 50801
would these components be the same nomenclature and would the readings be the same?
Thanks
kg
dpalmer76
Jun 3, 2005, 10:03 PM
Post #5 of 7 (2555 views)
Re: [kengcad] mitsubishi vs6017r [In reply to] Can't Post
The first thing I would check would bemy vertical deflection ic it is usually IC401. Also check the voltages going to the IC and change the pump up capacitor.
kengcad
Jun 4, 2005, 9:23 PM
Post #6 of 7 (2548 views)
I found some questionable caps and took some other readings. IM only getting about 17kv out of my flyback transformer. I wil change ic401 and see if that helps.
thanks ken
projectiontvman
Jun 13, 2005, 5:11 PM
Post #7 of 7 (2525 views)
This appears to be a major problem with Mitsubishi TVs. I have been doing research to document peoples problems with the projection tvs from mitsubishi.
I may be initiating a suit on behalf of purchasers so that Mitsubishi will provide assistance to its purchasers or provide replacement tvs. If anyone has any questions or wants to document their problem, please email me at projectiontvman@yahoo.com I will try to respond to you shortly. Sorry to hear about your problems.
