rca p60812bl ????????????
xxxnt
Aug 21, 2006, 3:15 AM
Post #1 of 4 (1285 views)
rca p60812bl ???????????? Can't Post
my rca p60812bl ptk195ac has had some issues lately it works fine when first turned on but once warmed up it will have big bows at the top and the bottom and the colors will separate. if you turn it off and on again it will be fine for a minute. if i try to goto the menu to try to adjust the color alignment the tv will shut off and come back on with good picture for a minute and then go back to the same problem
Aug 21, 2006, 8:26 PM
Post #2 of 4 (1276 views)
Re: [xxxnt] rca p60812bl ???????????? [In reply to] Can't Post
Check for bad solder joints on the convergence amp ic's first of all.
shadetree
Aug 22, 2006, 1:50 AM
Post #3 of 4 (1273 views)
it's usally the large ic on the board above the convergence module but there is a ic on the convergence module that will also cause this I will look when I go to the shop and get the numbers
kevin
Aug 22, 2006, 11:19 AM
Post #4 of 4 (1271 views)
could also be bad solder connections on the convergance power supply board, you should see it on the left hand side , mounted above the convergance board
