system shuts down
drrob
Jul 7, 2006, 5:18 AM
Post #1 of 3 (1389 views)
system shuts down Can't Post
I have a SDP62A3 Pioneer projection unit and I keep blowing the 4 amp fuse which causes the system to shut down.
Any idea as to what the cause of blown fuse?
coochieo
Jul 9, 2006, 4:11 AM
Post #2 of 3 (1378 views)
Re: [drrob] system shuts down [In reply to] Can't Post
there is a hundred things that could cause this need more info what you checked and not.you can start by disconecting the high voltage lead from the block and start the tv up and keep this lead away from anything best to stick it in a glass jar and if you here high voltage in jar stop and let us know unplug tv
ROB
drrob
Jul 11, 2006, 1:34 AM
Post #3 of 3 (1367 views)
Re: [coochieo] system shuts down [In reply to] Can't Post
Thank you for the reply. I took the wire off the black block that the large red wire that I assume is the high voltage lead. placed it in a jar. I turned on the tv and all I got was sound. I did replace the fuse that was blown and the red LCD light that comes on after the fuse blows went out. I put the wire back in the block and the picture came on and will remain on for a day or so but will blow the fuse again. I have not checked out anything else.
