toshiba 50h72
bowlin
Jul 18, 2006, 7:19 PM
Post #1 of 9 (2512 views)
toshiba 50h72 Can't Post
Dont wanna still from anyones thread but I am trying to work on my 50h72. Actually I wanna get to the 2 stk392's. I can see them and I am so near but, there is a couple things in my way and I dont wanna mess anything up. If I post a pic can someone possibly help me???
Jul 18, 2006, 8:22 PM
Post #2 of 9 (2507 views)
Re: [bowlin] toshiba 50h72 [In reply to] Can't Post
post away
bowlin
Jul 19, 2006, 2:53 AM
Post #3 of 9 (2501 views)
Re: [techchris] toshiba 50h72 [In reply to] Can't Post
maybe this is easier than I thought, posting the pics that is. the reason for so many pics is I wont you to get a fill for the delima, or maybe lack there of.
(This post was edited by bowlin on Jul 19, 2006, 3:08 AM)
Attachments: mydelima.JPG (649 KB)
Jul 19, 2006, 8:31 AM
Post #4 of 9 (2496 views)
you will need to unsolder the ic and the support pillars on the heatsink.then the whole lot will lift out of the pcb.if you change the ic's make sure you fit lots of new heat compound or they will fail again,and dont use cheapo Chinese ic's either
bowlin
Jul 19, 2006, 6:58 PM
Post #5 of 9 (2491 views)
ok you are talking about the big metal pc which the stk392's are attached to correct unsolder it as well? OK another newbie question hwo do I know if it has been soldered on, I know you know, but what do I look for???Sly
Jul 20, 2006, 9:39 AM
Post #6 of 9 (2490 views)
the metal heatsink has pillars that go through the pcb and are soldered into the circuit.If you have not done soldering before you will find this job difficult. you need to unsolder the two rows of connections on each ic and the heatsink pillars from underneath.you need a good soldering iron that is not too hot for the ic but will adjust hot enough to unsolder the heatsink pins and a good solder mop to soak up the old solder.
bowlin
Jul 20, 2006, 12:59 PM
Post #7 of 9 (2485 views)
Chris,
I hope this dont offend ya, but when you say soldered into circuit, does this mean my best bet is to take the whole board out of the tv and do it outside of the tv, the only thing holding the board in now. I think is a white peice that is connecting both boards, kinda hard to get to but will do my best.
Jul 21, 2006, 8:02 AM
Post #8 of 9 (2479 views)
usually screws around the edge holding pcb to plastic frame.the edge connectors flip up to disconnect,unplug any flying leads
bowlin
Jul 30, 2006, 1:50 PM
Post #9 of 9 (2441 views)
Took the board out last week, ordered the 2 392stk's, will take board and the new chips to work tomm and see if the maint. guys can help me do a little unsoldering and soldering. Hope to be putting board back in Monday night and watching tv sometime this week coming all wish me luck.
Attachments: board out.jpg (59.1 KB)
  new stk.jpg (58.4 KB)
