Repair man
Apr 1, 2009, 12:46 AM
Post #5 of 6
(1100 views)
Re: [ronlj1] Need value and rca part number for a surface mount capacitor C1572. It is an RCA model BD20TF10 and Chassis number TX-TVD809. It is located next to the IF IC 1160. Please respond as soon as possible. Thanks
Are there any markings on the cap? The following code marking systems are widely used for surface-mount resistors and capacitors. Resistor values are in Ohms and the capacitor values are in Picofarads. With the three symbol code, the first two digits are the base figures and the third is the multiplier (number of zeros to add). Example: "270" = 27 Ohms (27R) or 27pF. "331" = 330R or 330pF, "472" = 4.7k (4k7) or 4.7nF (4n7F). "2R2" = 2.2Ohms and "2P2 = 2.2pF. The two-symbol code uses a letter to indicate the base figure in Ohms or pF, and the second digit to indicate the multiplier: Here are 2 links, 1 will describe this and in more detail the other is a chart of values. I hope this info helps you find the value you need. Click Here Click Here ------------------------------------------------------------------------------------------ If you (or anyone reading this post) have any further questions or need clarification please feel free to contact me direct; you can find my email address by clicking on my user-name. Learn Plasma TV Repair _________________ Learn LCD TV Repair
