Aug 15, 2010, 2:27 AM
Post #3 of 4
(645 views)
Re: [dsirkin] degauss expert needed
dsirkin;...... Can anybody tell me what I might try? Looks like you need a new CRT or new TV..... Reasons are:... I can not degauss it completely with my (professional) coil. Unless it's a dinky little coil you are using .... Your "proffessional" coil should have taken out the impurity..... The "Proffessional" coil I use has about 10 times the strength the built in has OR ever will have.... It's not a detached shadow mask, as I can: It takes one helluva an effort to "detach" a shadow mask.... Usually when you have a "detached" shadow mask , the CRT is broken.... Your reasons #1 & #2 are meaningless for this problem.... I suspect that somewhere along the line that that TV was dropped.... What you describe is a "Warped" shadow mask.... It is NOT repairable.... My theory is (ahem...) that when the thermistor blew, a etc, etc.... Nice try....I don't want to embarrass you by blowing big holes in your theory........ Let's just say ...Nice try........ Replaceing the thermistor is a waste of time & money..... Will NOT solve your problem....... Sorry for the bad news.......... Good Luck..... Later....Ron.M..... Veteran & Retired TV technician
