andromeda
Oct 8, 2005, 12:51 AM
Post #5 of 6
(1226 views)
I removed the transformer and checked it on resistance, rather than 'beeper' The primary to primary on the transformer has a reading of 3.6Kohms, whereas the secondary side have a reading of close to 0 ohms. Their are some very small diodes that measure short both ways while in situe, but I've yet to take these out to measure them properly. The solenoid thing seems to come from a big chip with hundreds of legs, and the other side is to the transformer through a couple of resistors and diodes. If it is this chip thing, then i presume that it is landfill. Also, what is the solenoid thing for? if it a kinda cut off thing, then will I be able to short the 2 pins and skip the solenoid, to make it work?
