Jul 1, 2005, 10:20 PM
Post #2 of 5
(1534 views)
Is the "cracklig noise" coming from inside the set or thru the speakers. If from inside the set, it is probably a high voltage arc due to breakdown in insulationin the high voltage section. You should be able to spot it in the back of the set. Sometimes, a little Silicone Seal will cure the problem.
