Akai LCT3201AD
jhh2j
Feb 1, 2012, 4:27 AM
Post #1 of 9 (1533 views)
Akai LCT3201AD Can't Post
I recently replaced three capacitors on the power supply board; however, I accidentally reversed the polarity of the capacitors. When I plugged in the TV, I heard a surging sound. Now, there is absolutely no power to the TV. Not even a standby light. Any ideas as to what has happened? Thanks.
Feb 1, 2012, 8:48 AM
Post #2 of 9 (1525 views)
Re: [jhh2j] Akai LCT3201AD [In reply to] Can't Post
You applied power with the electrolytics installed backwards!
jhh2j
Feb 1, 2012, 7:25 PM
Post #3 of 9 (1514 views)
Re: [jts1957] Akai LCT3201AD [In reply to] Can't Post
Unfortunately, I did install capacitors reversed by accident. Do you have any idea as to what might of happended? Like I said, I heard a surging sound. Also, none of the capacitors blew or bulged...
Thanks.
Feb 1, 2012, 10:44 PM
Post #4 of 9 (1507 views)
Normally, an electrolytic cap installed backwards will explode. Apparently some other component (hopefully a fuse) went first.
Feb 2, 2012, 6:13 AM
Post #5 of 9 (1503 views)
Re: [mel] Akai LCT3201AD [In reply to] Can't Post
Now the electrons and positrons are probably confused about which way to flow.Wink
jhh2j
Feb 3, 2012, 4:03 AM
Post #6 of 9 (1492 views)
Is there anything I can do to revive the PSU, or is it trash?
Feb 3, 2012, 8:44 PM
Post #7 of 9 (1486 views)
jhh2j;....
I do not work on LCD,LED or plasma TVs , but I can give you very limited help....
That said....
You may have blown the new caps....
Even tho they don't look bad or are not bulged they can be blown internally...
They are cheaper than a new PSU or TV....
Before you toss it , I'd suggest you get another set of caps & install them CORRECTLY....
Then check/replace the fuse & give it a go...
Good Luck....Sly....
Later...Ron.M...Cool...
usman0092
Feb 4, 2012, 3:18 PM
Post #8 of 9 (1474 views)
Re: [Ron.M] Akai LCT3201AD [In reply to] Can't Post
They usually have them available for downloading at their websites.
____________________
[Url=http://www.versionfull.com/search/accounting-software/1]free accounting software
Feb 4, 2012, 6:49 PM
Post #9 of 9 (1465 views)
Re: [usman0092] Akai LCT3201AD [In reply to] Can't Post
usman0092;....
You need to get this fixed;=>....
OR see a shrink !!!!
.....Ron.M....Cool....
