Amp vs pre-amp
wonderboy1953
Jul 9, 2011, 8:11 PM
Post #1 of 4 (1240 views)
Amp vs pre-amp Can't Post
What's the difference between a tv antenna that's an amplifier vs one that's pre-amplified, i.e. with respect to reception?
Repair man
Jul 12, 2011, 3:35 AM
Post #2 of 4 (1226 views)
Re: [wonderboy1953] Amp vs pre-amp [In reply to] Can't Post
A pre-amp goes at the head end (Up on the antenna itself) as opposed to an amplifier that goes somewhere near the bottom usually behind the TV or somewhere between where the antenna cable enters the house & your TV.
A preamp is better because of where it is mounted, with it being at the head end it amplifies the signal while it's at it's strongest which give you a better chance at keeping a good signal. If you have an amplifier in line near the bottom the signal is often lost due to line loss in the co-ax and never makes it to the amplifier in which case the amplifier cannot amplify what is not there.
Sometimes these terms mean the same thing; an amplified antenna means pre-amp. If the amplifier is attached to the antenna its a pre-amp.
Learn Plasma TV Repair
_________________
Learn LCD TV Repair
(This post was edited by Repair man on Jul 12, 2011, 3:37 AM)
wonderboy1953
Jul 13, 2011, 10:20 PM
Post #3 of 4 (1214 views)
Followup question [In reply to] Can't Post
First, thanks for your response.
I've heard good things about the Kitztech tv antenna (website: www.kitztech.com/). Do you have experience with it?
Jul 14, 2011, 2:00 AM
Post #4 of 4 (1208 views)
Re: [wonderboy1953] Followup question [In reply to] Can't Post
IF antenna has broken/missing elements, is corroded or just plain worn-out ... NO amount of amplification will improve.
