Blink rate question
Aug 23, 2006, 9:18 AM
Post #1 of 2 (950 views)
Blink rate question Can't Post
Hi my question is the fault blink code, does this relate to the stage, IE 4 blinks = IC401 the vertical IC etc or am I being too rational
sheldonstv
Aug 23, 2006, 11:05 AM
Post #2 of 2 (946 views)
Re: [rrobor] Blink rate question [In reply to] Can't Post
Smilethese fault codes where the standby led blinks x amount of time only give a rough idea as to where the fault(s) may be.......as an example an icc20=the led blinks 2 times then 5 times=error code 25 which relates to the switched 5v supply being missing-in my case it was present for a couple of seconds as was the ht and line drive together with a short burst of eht-the fault was due to clo33 being oc which is in the line op stage-other things such as the frame ic also can cause it.
all errror codes can only give a general area of where the fault could be
