Aug 24, 2006, 11:55 AM
(917 views)
sounds like you have a short circuit somewhere causing the power supply to shut down.check the horizontal out transistor ,it is probably short circuit collector/base. If not then take it out of the board,switch on and see if the tv power supply runs. also check the 120volt supply diode off the smps tx
