May 18, 2014, 5:16 PM
Post #3 of 10
(1501 views)
Re: [Sam1] CRT Repair Question
Sam1;..... 1st off , a model number would've probably gotten you a response by now.... So it's time for that.. & a chassis number would also be helpful....
I'm assuming this isn't something I can fix myself. That depends on the nature of the problem & ""How much electronic/TV repair background experience do you have ????""" A pix would give us a much better idea of what the problem is.... Can you take & post pix ????....
if I call someone to adjust it, is it likely that they can fix the problem (or at least get close-- say 95%)..? Or is it more likely that after they adjust it the bending will be slightly better but still noticable and I won't be able to get a refund..? Depends on the quality , integrity & technical ability of TV repairmen in your area !!!!...
Can a tv repair pro hypothetically fix this (or very nearly so) by doing some adjustments or not? Hypothetically , weeellll , yes , maybe ...
Or is it some massive effort like replacing 100s of capacitors? NO , NOT likely... Later...Ron.M.... ... Veteran & Retired TV technician
