CRT white screen
Dan_Rea
May 29, 2008, 10:57 PM
Post #1 of 3 (1305 views)
CRT white screen Can't Post
im a novice tv technician at best. a blundering self-taught electrocution-hazzard is more likely the accurate description. would anyone in here know anything about a problem with a tv that im trying to fix right now?
its a CRT and all i got was a black screen. i replaced the big capacitor next to the power supply which was a little crispy, and now all i have is a white screen. ch+- and vol+- nor the AV button have any effect. the spreakers arent connected so i cant test if i have sound. no lines on screen, just white. ive never had a white screen and im afraid it could be a shorted crt so i thought id ask someone with a brain on their shoulders before hooking up the speakers.
plz reply in a nice dumbed-down language i can understand, no acronymns thx. would be thrilled if someone could help me out. cheerio
---i have a feeling something to do with video output could be stuffed and all coulours are firing at full, creating a white screen.
(This post was edited by Dan_Rea on May 30, 2008, 2:24 AM)
May 30, 2008, 6:43 AM
Post #2 of 3 (1296 views)
Re: [Dan_Rea] CRT white screen [In reply to] Can't Post
it would be good to check if you have sound.in the meantime check for about 200 volts (approx) on one lead going to the tube base board, from the flyback tranformer area.if you have not then the problem is the ic on the tube base (video driver) has gone faulty and taken out a low value resistor feeding the voltage to the ic.this will be either on the tube base itself or the main board by the flyback transformer.I dont have a diagram so I cant give you the position numbers,but someone else may post this info with luck
Dan_Rea
Jun 1, 2008, 5:03 AM
Post #3 of 3 (1273 views)
Re: [techchris] CRT white screen [In reply to] Can't Post
i feel your comment will be very helpful to me. thankyou very much for the reply, mate.
