CT32D11CE Panasonic
chipset
Mar 26, 2011, 9:01 PM
Post #1 of 8 (1331 views)
CT32D11CE Panasonic Can't Post
Well i think she is done. The HOT had a dead short from the collector to emitter. Replaced the HOT. Got the tube back. Now the colors are completely washed out and out of focus. Tube is very bright. Very weak picture quality. You can see the horizontal lines across the screen about one and half inch apart from the top to the bottom. Picture was perfect before it blew. Worked perfect that night and the next morning it was dead. The set is 9 years old and hoping to fix it. I'll use it in my man cave and buy a new set if i have to. I'm thinking the flyback is done. That is what gives it it's focus, well on a computer monitor anyway. Any
ideas out there ? The only thing that was changed or
touched was a new HOT 2SC5339 and two 220 caps in
the Z board. Thanks in advance.
greg
Mar 26, 2011, 10:45 PM
Post #2 of 8 (1324 views)
Re: [chipset] CT32D11CE Panasonic [In reply to] Can't Post
chipset;.......
This the same set as;=>....
http://www.tv-forums.com/...cgi?post=93818#93818
I'm sure jts1957 would be willing to jump back in....
Did you check R760 like he suggested ???
That said....
Have you tried to adjust "G2" on the flyback ???
Looks to me like during the repair you "may" have moved it...
Turn the TV on & turn the "G2" control on the flyback counterclockwise till the pix gets darker & the horizontal lines go away....
Check your pix & post results....
If needed , adjust the "focus" for pix clarity....
FYI;....
The G2 & Focus controls are on the rear or right side of the flyback & are marked....
Good Luck.....Sly.....
Later...Ron.M....Cool....
chipset
Mar 27, 2011, 5:08 PM
Post #3 of 8 (1315 views)
Re: [Ron.M] CT32D11CE Panasonic [In reply to] Can't Post
NO. This is a different set. I got the 27 inch fixed last month. 4 bad caps. Been awhile. I forgot all about the
G2. Have not replaced R760. it's N.L.A. I'll look around
and see if anyone has a scrap CT32D11CE and get the
entire Z board. I hope. Funny thing though is the G2 almost always needs to be readjusted on a monitor
when the HOT is replaced. Thanks, Ron. I forgot about
it. Been awhile. I'll let you know how it turns out later
in the day.
Mar 27, 2011, 5:48 PM
Post #4 of 8 (1310 views)
R760 for width/side pincushion symptoms. Any PC mount 4.7/5K pot should do. Best to triple check regarding value, since there appears to be some confusion in their description.
http://www.mcmelectronics.com/...Y-MCM-28-490-/28-490
Mar 27, 2011, 6:36 PM
Post #5 of 8 (1308 views)
chipset;....
You wouldn't be fibbin me would you ????
From here posted on Jan,24,2011;
I get;...
Panasonic 32"
mod-- CT32D11CE
chassis # EP341
April 2001
in the 1st post ^^^....
And HERE in THIS thread in your 1st post it says;
CT32D11CE....
Sure looks like the SAME set to me !!!!
Added to that ,
the Z board.
From your 1st post here ^^^ which was EXACTLY what you were working on with the other thread !!!
ALSO;...
SAME as the other thread !!!
Either I'm drunk or had a stroke , but that looks like a duck , walks like a duck & quacks like a duck , so it's a dam duck !!!!
SO this set IS the SAME one , RIGHT ???
I was born at night ,but, NOT LAST night !!!
Care to clarify that ????
BTW;...
R760 has NOT been determined bad yet that I can see....
jts1957 suggested you "check" it...
You did not post results....
Later...Ron.M...Cool....
chipset
Mar 27, 2011, 11:11 PM
Post #6 of 8 (1299 views)
I'm confused and i think i screwed up. Yes this is the
same set as in Jan 27 or there abouts. I did fix my 27
inch months ago. This is the same 32 inch that had the
horizontal sync problem and it just puked thursday.
Just finished an AODE transmission rebuild and i'm beat.
I still have to install it. I'll do that tomorrow. I'll work on my T.V. maybe tonight. I'll keep you posted.
Thanks for all your help.
Mar 28, 2011, 4:37 PM
Post #7 of 8 (1289 views)
http://www.youtube.com/watch?v=wCy8MpT45gk
chipset
Mar 28, 2011, 5:58 PM
Post #8 of 8 (1287 views)
Re: [jts1957] CT32D11CE Panasonic [In reply to] Can't Post
Made the G2 adjustment and focus. Working now and
acceptable. I just have to work on the R760. That
problem is still present. Don't feel like installing a transmission. I'll work on my set. I'll go back to the
posts and reread all suggestions. Beats twisting a wrench.
Thanks for all the help. Haven't worked on a monitor or
T.V. in 7 years but it's coming back thanks to all of you.
