TonyC
Apr 18, 2006, 3:46 AM
Post #1 of 8
(3256 views)
I posted a issue with this set last month. It still has a problem with cycling on/off after 2-3 minutes . After getting a schematic and digging into this deeper the following information is new. From the service menu the error code display indicates an 8=xray shut down. I have gone through this circuit carefully and replaced Q14901 with replacement part number 147665. I still get the shutdown. I lifted CR14901 to disable the shutdown, the set appears to be fine. To date I have replaced the following, the flyback (T14401), HOT (Q14401) and Xray switch (Q14901) Checked solder joints and resoldered L14401,T14401, Any suggestions? as many as possible would be great. I will recopy the original posting thank-you for your help. Tony C. Original posting: M/N F32648YX57 S/N 048421857 Chassis CTC203CA6 I have an RCA set with a problem that originally had the following symptoms: When power on button is brought in a very loud arching sound comes from the back. When the back cover was removed, it was obvious that the flyback was the problem by the 2 inch arch coming from it. Other power off component checks were made with no other real issues appearing to exist. A new flyback and HOT were ordered. Both were installed. Now the set powers up with good audio/video and shuts down within 3-5 minutes. This continues at an increasing rapid rate until it is manually shut off. The flyback part number that I got through reference was 247718. The replacement I got is made by TOSEI and its number is 4084. Are these any good? I was originally going to get an OEM replacement however, this was more readily available. I read a posting with a problem just like this and it ended up being a questionable replacement flyback. I checked all of the solder joints with a magnifier and also L14101, nothing found. I haven’t ordered a schematic yet because I was hoping to not get that far into this one until I asked around. Any feedback would greatly be appreciated. Thank-you Tony C.
