Dec 18, 2004, 12:22 AM
Post #2 of 4
(2011 views)
Re: [plat] Convergence problem?
Unless the purity magnet is bonded to the neck of the CRT, convergence is accomplished by adjusting the tabs behind the yoke on the neck of the CRT. To do a proper job, you really need a cross hatch generator. You can do a rough job by turning off the color and adjusting the back four tabs for the best convergence. Do not mess with the front tabs as they are the purity magnets. This job is actually best left to someone with the proper knowledge and equipment. If the purity magnet is bonded, there is no way to adjust it.
