Dead Sony klv-40a10
ghylousan
Jan 17, 2015, 10:36 PM
Post #1 of 25 (3577 views)
Dead Sony klv-40a10 Can't Post
Hi, <br>I've got a dead Sony klv-40a10 PCB 1-866-161-14. <br>No stb 5 V, i've chaged IC 6300 STR A 6169, PH 6300 PC123Y22JOOF, <br>there is aroud 185Vac on pin 5 of STR A 6169, verified all diodes, capacitors, resistors aroud this circuitry, all good, so where do i go next ? <br>
(This post was edited by ghylousan on Jan 18, 2015, 4:59 PM)
Jan 18, 2015, 12:24 AM
Post #2 of 25 (3574 views)
Re: [ghylousan] Dead Sony klv-26a10 s32 [In reply to] Can't Post
Correct your model number, then substitute your bench 5VDC supply for the TV's stb 5 V.
(This post was edited by jts1957 on Jan 18, 2015, 12:25 AM)
ghylousan
Jan 18, 2015, 5:02 PM
Post #3 of 25 (3553 views)
Re: [jts1957] Dead Sony klv-26a10 s32 [In reply to] Can't Post
Thank you, i had the model wrong, so you said to substitute the stb 5 V with an auxiliary 5V, so what shall i gain with this procedure ?
Thank You for your time
Jan 18, 2015, 7:25 PM
Post #4 of 25 (3547 views)
You STILL have NOT corrected 'S' your model number (in the Subject line). 0 Results found in All for "klv-40a10" http://www.sony.co.uk/...A10&locale=en_GB Unimpressed
btw, Apparently YOU are the ONLY person on the planet Earth to have 'that' board number. Frown
Pin 5 on my 40" power supply schematic says (aroud) 154 vDC. IF you are getting AC OUT of D6300 - I think you've found your problem.
To know you are on 'the right track.'
May (or may not) show additional problem(s). (For example: a bad panel.)Crazy
(This post was edited by jts1957 on Jan 18, 2015, 7:56 PM)
ghylousan
Jan 18, 2015, 10:51 PM
Post #5 of 25 (3532 views)
Re: [jts1957] Dead Sony klv-S40A10 [In reply to] Can't Post
OK the board is 1-868-161-14, i have 157 VDC between pin 5 and 3, the model:KLV-S40A10, Canada 110Vac
Jan 19, 2015, 12:09 AM
Post #6 of 25 (3525 views)
Re: [ghylousan] Dead Sony klv-S40A10 [In reply to] Can't Post
AND
then substitute your bench 5VDC supply for the TV's STBY5V? (Presumes STBY5V 'line' is NOT dead short)
(This post was edited by jts1957 on Jan 19, 2015, 1:35 AM)
ghylousan
Jan 19, 2015, 5:30 PM
Post #7 of 25 (3504 views)
OK, Front LED flashing 5 time.
Jan 19, 2015, 7:11 PM
Post #8 of 25 (3501 views)
Rest of STR-A6169 pin voltages?
G3 Board A-1148-761-D
Overall Power Supply Protection (5X Flash Pattern)
ghylousan
Jan 19, 2015, 7:46 PM
Post #9 of 25 (3499 views)
Pin1- 0V, 2- 15.75 Vdc, 4- 0v, 5 and 7 and 8 157Vdc <br> IC6421 PQ12DZ5UJ00H ??
(This post was edited by ghylousan on Jan 19, 2015, 7:51 PM)
Jan 19, 2015, 8:39 PM
Post #10 of 25 (3494 views)
IC6301 MM1431ATT ??
ghylousan
Jan 20, 2015, 6:10 PM
Post #11 of 25 (3469 views)
Took the MM1431ATT out, Applied 5v through a 10K to pin 1, 2 gnd and got .917 on pin 3.
ghylousan
Jan 21, 2015, 9:48 PM
Post #12 of 25 (3463 views)
OK, so changing the PCB (1-868-161-14) board would do the trick ?
Jan 22, 2015, 12:55 AM
Post #13 of 25 (3462 views)
Probably.
If you have a second external supply you could try replacing stby5 volt and 16.5V simultaneously (check 16.5 for dead short first).Unimpressed
ghylousan
Jan 23, 2015, 5:31 PM
Post #14 of 25 (3445 views)
There is no 16.5V, only multiple 17.5V, 10.5V and 5V noted on the board
Jan 23, 2015, 7:06 PM
Post #15 of 25 (3442 views)
Finger f*rt.
D6903 cathode.
ghylousan
Jan 24, 2015, 12:34 PM
Post #16 of 25 (3429 views)
Do you mean to feed 17.5V on the D6903 cathode ?
Jan 24, 2015, 1:17 PM
Post #17 of 25 (3427 views)
Yes. CYM.
ghylousan
Jan 30, 2015, 8:55 PM
Post #18 of 25 (3383 views)
Hi, sorry for the late response,out sick, bad virus this year.So i fed the 16.5V and 5 V at the same time, still have 5 pulse on front LED.
hpv1965
Jan 31, 2015, 1:15 AM
Post #19 of 25 (3379 views)
Make sure you have gotten rid of that virus before you infect others!! Hahaha!!!
(This post was edited by hpv1965 on Jan 31, 2015, 1:28 AM)
Jan 31, 2015, 3:28 AM
Post #20 of 25 (3347 views)
Standby 5V supply has B plus. 2 out of the three semis that are involved have been changed. Not sure what you do to 'verify' other parts (I try to measure parts in circuit, but upon any oddball results I'll isolate and test them out of circuit) and both outputs have no shorts and can accept the voltages they are supposed to handle.
Reverify R6302 value.
Change C6306 & especially C6308.
I'm pretty much out of ideas after this.Frown
ghylousan
Jan 31, 2015, 6:12 PM
Post #21 of 25 (3329 views)
Ok, R6302 good, changed C6306,C6308, still no 5V, so if i change the entire board, maybe ?? How can i check tcon and other board to be sure.Thank you for the time you spent on this .
Jan 31, 2015, 7:09 PM
Post #22 of 25 (3328 views)
IF changing the power board doesn't get your 5V standby back, I don't know what will.
The Training manual only mentions your 40" model once. It's meant to cover the 26" & 32," but I haven't been able to find any other manual. The Service Manual covers your 40."
Although the power boards ARE different (G2 versus G3), they appear to contain many of the SAME circuits/parts. Main boards are also different.
Neither cover the 'logic board' other than to claim it is part of the panel assembly. It needs Digital Video and another 5V source.
austin1966
Feb 5, 2015, 2:27 AM
Post #23 of 25 (3261 views)
(This post was edited by austin1966 on Feb 5, 2015, 2:34 AM)
ghylousan
Feb 9, 2015, 8:21 PM
Post #24 of 25 (3186 views)
Hi,
Just a very simple check, if i just put the 110ac and nothing else, should i get the 5Vstb ? I yes, i just have the change the board, right ?
Thank You again
Feb 9, 2015, 9:32 PM
Post #25 of 25 (3185 views)
I would say yes.
