flyatyou66
Jul 23, 2014, 2:59 AM
Post #2 of 3
(959 views)
Re: [joeshannallie] Element FLW1920B Issue
I've seen this before with double picture.It is most likely a bad LCD panel (the actual LCD is failing.) It may or may not be fixable. Can you get hold of a freeze spray can or compressed air can? Spray all four edges of the lcd panel where it meets the plastic with freeze spray,if the picture comes back tempory,then its the panel at fault,the freeze spray will tighten up the contacts around the tab bonds. Try to wiggle the panel .is there any change? If you want to search youtube theres a foam fix for this issue. Sometimes it works, but the actual problem is where the tabs go into the screen.These crack due to age and heat.
(This post was edited by flyatyou66 on Jul 23, 2014, 3:23 AM)
