Ferguson D59F
ikc2
May 20, 2009, 9:22 AM
Post #1 of 10 (1337 views)
Ferguson D59F Can't Post
hi, another old set i have and this one works fine most of the time but sometimes during operating flyback lines will appear on screen and either go away after a minute by itself or the set will shutdown and restart i will post a picture of it when i get my usless phone working again.
May 20, 2009, 7:30 PM
Post #2 of 10 (1333 views)
Re: [ikc2] Ferguson D59F [In reply to] Can't Post
probably noisy screen control on the flyback transformer or faulty crt
ikc2
May 20, 2009, 7:44 PM
Post #3 of 10 (1331 views)
Re: [techchris] Ferguson D59F [In reply to] Can't Post
well i've checked the tuning on the flyback and its perfect so, do you think it may be the CRT?
May 20, 2009, 7:53 PM
Post #4 of 10 (1329 views)
check the earthing pin on the flyback tx for dry joints. if ok try tapping the neck of the crt gently with a wooden spoon it will induce the fault if the crt is sparking internally. otherwise you could monitor the screen volts to see if it jumps up and down when the fault appears
May 21, 2009, 1:21 AM
Post #5 of 10 (1325 views)
Do the "flyback lines" you're talking about appear on the whole screen or just, for example, near the top of the screen? If just near top, could be a lytic in the vertical output area (although set usually won't "shutdown and restart" in that case).
May 21, 2009, 8:34 AM
Post #6 of 10 (1320 views)
I believe Chris is correct it probably is the earth pin of the flyback transformer dry. Dont know this set but NEC had a model that did that but it was internal in the transformer.
ikc2
May 21, 2009, 10:05 AM
Post #7 of 10 (1318 views)
Re: [jts1957] Ferguson D59F [In reply to] Can't Post
here's what its like.
[URL=http://img20.imageshack.us/my.php?image=24032009513.jpg]
ikc2
May 21, 2009, 10:07 AM
Post #8 of 10 (1317 views)
http://img20.imageshack.us/img20/2562/24032009513.jpg
copy and paste link into address bar to view fullsize
May 21, 2009, 8:11 PM
Post #9 of 10 (1312 views)
looks like crt faulty.have you tried previously mentioned things?
ikc2
May 21, 2009, 10:12 PM
Post #10 of 10 (1310 views)
yes i checked flyback for dry joints everything was ok, so looks like the CRT then?, its not really a problem any more, i've retired this set as of today and i am using a phillips 21PT442A in its place which although has a smaller screen, perforemes much better and quicker and it has a better picture, the ferguson was real slow at performing commands anyway.
