Jun 19, 2007, 7:08 AM
Post #2 of 4
(1015 views)
Re: [Mules001] Fusible Resistors
When you buy resistors they are wattage rated. Most normal resistors are carbon. No fusable resistor is carbon, it is a metal film on a ceramic rod which makes it flameproof. If you replace a protection resistor with a standard resistor you then take all responsibility for the damage that may cause, whether that be fire or electrocution. Think very carefully whether you want that liability for a minor extra cost.
