Larry E
Aug 26, 2006, 7:17 PM
Post #2 of 9
(1934 views)
Re: [mark30] G.E 32inch buzzing
sounds like a short on the B+ line making the switch mode transformer buzz, first thing to do is re-solder the horizontal driver transformer, remove L4401 and clean the wax off the legs and then re-install it and try the set, if it still buzzes you either have a shorted HOT or flyback transformer, the ctc203 chassis`s are notorious for bad flybacks and many of them (you didn`t give a model number) are NLA, they make several different ones for various model numbers, try the solder re-work first, Larry E
