Grundig CUC4510 Dead
clifton11283
Oct 1, 2008, 9:23 AM
Post #1 of 6 (847 views)
Grundig CUC4510 Dead Can't Post
Hi,
I got a Grundig CUC4510 dead and there's a squealing noise coming from the set. I replaced the electrolytics in the power supply but the set remained the same. Anyone got an idea what could be faulty??
Thanks in advance
Oct 1, 2008, 6:44 PM
Post #2 of 6 (839 views)
Re: [clifton11283] Grundig CUC4510 Dead [In reply to] Can't Post
check the horizontal out transistor for short circuit.if it measures ok, take it out of the board switch on and see if you have about 120 volts on the centre pin where t it was soldered in.if you have then the fault is probably in the flyback/scan circuitry
clifton11283
Oct 1, 2008, 8:04 PM
Post #3 of 6 (837 views)
Re: [techchris] Grundig CUC4510 Dead [In reply to] Can't Post
HI again,
I found 163Volts. Is that ok? sorry if i'm asking silly questions but I just finished my school and I still need some practice for the job:)
Could it be that the EHT transformer is faulty since the squealing noise seems to be coming from it!!
Thanks a lot for your help!!
Oct 1, 2008, 8:38 PM
Post #4 of 6 (834 views)
if that voltage drops low with the transistor in circuit then the transformer is probably croaked.
clifton11283
Oct 2, 2008, 5:57 PM
Post #5 of 6 (828 views)
I replaced the EHT transformer and the set remianed dead!! Unsure
Oct 2, 2008, 8:57 PM
Post #6 of 6 (823 views)
what voltage do you have on the collector pin of HOT with it in circuit?
