Grundig tv problem
JasonTabone
Mar 3, 2011, 10:32 PM
Post #1 of 2 (791 views)
Grundig tv problem Can't Post
I have a grundig tv st70 2500Top and when it is switched on a tricle noise is heard and it is switched off again but the front red led remain on. I had suspect that the smps is being overloaded due to a faulthy component. I had started to chech the secondary diodes by disconnecting them but it is still making the fault. I had disconnected D611,D613,D614, and D612. I had also removed the line output transistor. The problem is still persists. Do you have a remedy for this problem thanks.
Jason Tabone
JasonTabone
Mar 4, 2011, 11:50 AM
Post #2 of 2 (782 views)
Re: [JasonTabone] Grundig tv problem [In reply to] Can't Post
When checking secondary voltages they were too low but when disconnecting D615 diode and checking again the voltages on the secondary they were ok. I had connected again D615 and removing th601 thyristor the voltages are still ok but when i try to start the tv from front button it will go again to standby.
