HELP..Lines On Screen
Asian Tiger
Apr 23, 2005, 2:07 PM
Post #1 of 2 (1469 views)
HELP..Lines On Screen Can't Post
Please could someone help me with an issue regarding my television.
I have a JVC television, model number "AV-25SX1EK" and when its switched on there are white lines across the top of the screen. This occurs in both 4:3 and 16:9 mode and intermittently the picture will also flicker, turning black. Is this a problem that can be repaired, or am i better off chucking it.
Apr 23, 2005, 9:04 PM
Post #2 of 2 (1462 views)
Re: [Asian Tiger] HELP..Lines On Screen [In reply to] Can't Post
The foldover at the top of the screen is caused by bad electrolytic capacitors in the vertical circuit and the flicker is probably caused by a bad solder joint. Both problems are repairable but you need to consider the coat of repairs as apposed to the cost of a new set.
