HELP PLEASE!!
vincentDC5
May 23, 2018, 4:44 AM
Post #1 of 4 (1265 views)
HELP PLEASE!! Can't Post
Hi guys,
I have had this Vizio TV for a few years now, and it's been working like a charm until recently i started seeing the bottom 10 or so lines would flicker and eventually the screen is just went out completely.
Here are a few things i noticed when i took it apart:
1) Backlight still comes on, and everything still runs like normal. I can get Netflix to run and play. I can hear audio, but see no picture. Only the dimming/ localized lighting from the back light.
2) I do see a small patch shown in the following corner:
https://imgur.com/a/168WoU3
3) If i unplug the right panel connector from the T-con board, the left side picture would come back on (i see netflix and all..).
4) But i can only get the left side picture to show if i plug the left side panel into the t-con board. I've tried all other possible combinations (right to left, left to right, unplug left only...), and all will yield to the same blank screen results from 1).
So I originally thought, this must be the t-con board, but I've just replaced it with a new one, same results.
Here's the model number:
Vizio e50-c1
Would it be the logic board? the panel?
Thanks for the help in advance guys! I am super noob at this. And would appreciate any feedback or experience sharing.
Thank you all!!
Vincent.
May 23, 2018, 4:54 AM
Post #2 of 4 (1264 views)
Re: [vincentDC5] HELP PLEASE!! [In reply to] Can't Post
Sounds like Panel.
vincentDC5
May 23, 2018, 6:52 PM
Post #3 of 4 (1232 views)
Re: [jts1957] HELP PLEASE!! [In reply to] Can't Post
Thanks for the reply jts1957!
Would this be something thats repairable/ worth repairing?
Thanks,
Vincent
May 23, 2018, 9:13 PM
Post #4 of 4 (1230 views)
Not usually.
