Mar 24, 2013, 7:49 PM
Post #2 of 6
(7224 views)
Re: [matty-chatty-95] Hannspree tv fault
Since you don't say which input it comes up on ... Some manufacturers build in a "Turn Off if nothing is active on the input that is currently selected" feature. If set was turned off when set to VGA input and now has nothing even connected to that input, it wiil start up as you describe, then go back to standby. Either change the input on the TV during the first 20-30 seconds (IF it will let you), or connect an antenna or ACTIVE device to the indicated input (or each input in turn). Of course, I could be barking up the wrong tree all together .... ------------------------- Location: Far, Far Away
