RetiredTVguy2
Aug 7, 2007, 1:50 PM
Post #11 of 17
(2374 views)
Re: [specialeedd] Help PLEASE help
Dont buy anything just yet, unplug the set and open it and look to see if you have this resistor, location R715. It should be a 158K ohm resistor or it could be 113K. Set your meter to x10K calabrate it to full deflection (0 ohms) then pull out the board (you may have to disconnect some leads, make sure you remember where they go) DO NOT!! ATTEMPT TO DISCONNECT THE WIRE TO THE PICTURE TUBE!! Even with the set unpluged it can hold a serious high voltage charge!! Turn the board on it's side, wick out (unsolder with unsoldering wick) one leg of that resistor, turn the board back over and test the resistor. If you get "0" ohms or if the needle doesn't move at all the resistor is bad and you need to replace it. If you get a reading somewhere in between then it is most likely good. But first lets find out if you have that resistor in the first place. It shuold be near the Horz out transistor which is near the flyback transformer (sends that wire to the pic tube that your not going to touch), it will be under a larg "white" resistor that is standing up about 1/2 to 1 inch off the board and should be marked a wattage value of 20watts. Let me know. ---------------------------------------------------------- When everyone treats you bad, turn to your dog, he or she will understand! ----------------------------------------------------------- I dont mind working, as long as it doesn't interfere with fishing!
