JohnRocks
Mar 10, 2012, 7:17 AM
(931 views)
Re: [rwlacks] Hitachi 53udx10b
Sounds like to be you have a bad solder joints, check solder and make sure that they are still attached Or Do you hear a relay click, Have you unplugged and plugged the set back in? Short of opening the set up you probably have a power supply/deflection issue and will require a TV technician. ----------------------------------------------------------------- Rackmount LCD Monitor USB KVM
