Sep 2, 2009, 12:17 PM
Post #14 of 15
(2111 views)
Check to see how the board is secured to the neck of the tube, some mfg. use clamps, some a blob of hot glue. Some use both. Take a box cutter and CAREFULLY cut through glue even with where the socket and tube join. "Rocking/pulling" board off as you do so. If neither method works, you could always take just a little "C-4" ... takes it right off! ------------------------- Location: Far, Far Away
