Jungle IC
Paulpablo
Jun 29, 2006, 2:30 AM
Post #1 of 6 (1620 views)
Jungle IC Can't Post
How in the world do you de-solder and re-solder a jungle I.C.? When they come into my shop with that problem, I just condemn the set! The Manufacters don't want you to repair these sets. they just wan't you to buy a new one. made in CHINA!
Jun 29, 2006, 9:33 PM
Post #2 of 6 (1608 views)
Re: [Paulpablo] Jungle IC [In reply to] Can't Post
Use a solder sucker to desolder. Resoldering is a piece of cake with a 25 watt pencil iron.
Paulpablo
Jun 30, 2006, 3:00 AM
Post #3 of 6 (1604 views)
Re: [mel] Jungle IC [In reply to] Can't Post
I am getting too old and feable for this game. as I can't see this well anymore.The golden years can kiss my ass!
Jun 30, 2006, 9:43 AM
Post #4 of 6 (1599 views)
Rubbish, if you are surethe IC is faulty use a stanley knife o cut the pins off at the side of the ic. Now with solder wick, clean the pads off. With pencil iron, put a pad of solder on the cleaned pad at each corner, fit the new IC and solder the corners, check if OK, if so solder all contacts. Use best and thiinest solder you can get, and check joints do solder as non lead solder is not so easy.
Jun 30, 2006, 10:49 AM
Post #5 of 6 (1597 views)
use lots of flux to prevent solder running and shorting pins
Jun 30, 2006, 9:40 PM
Post #6 of 6 (1594 views)
I doubt that you are older than I am and I'm still at it. I use a pair of storebought 3.75 diopter reading glasses for close up work.
