KDL-37M4000 power surge
RobOnMV
Jul 24, 2011, 2:55 PM
Post #1 of 18 (2374 views)
KDL-37M4000 power surge Can't Post
Hello all. The above set is on the blink. No power at all after a bolt of lightening blew out the transformer in front of the house. I live on an island, and a repair person to come over is at a premium. I've swapped out many parts on our laptops over the years, but never opened up a tv before. From here and elsewhere it appears my power supply is shot. That said I've found one on EBay for about $100. Do you think that is the issue, and if so, how involved is it to swap out? I no nothing of voltage meters or any of the usual tv repair jargon I see here(wish I did). Any help you can send over is greatly appreciated.
JadeFalcon
Jul 24, 2011, 3:06 PM
Post #2 of 18 (2373 views)
Re: [RobOnMV] KDL-37M4000 power surge [In reply to] Can't Post
have a look on the power supply board inside the tv there is usually a fuse on the board, i would test that to see wether it has gone bang, before you even think of replacing the board
RobOnMV
Jul 24, 2011, 3:17 PM
Post #3 of 18 (2371 views)
Re: [JadeFalcon] KDL-37M4000 power surge [In reply to] Can't Post
Thanks - will do, but how do you check to determine whether the fuse is shot or not?
JadeFalcon
Jul 24, 2011, 3:25 PM
Post #4 of 18 (2370 views)
do you have a multimeter to hand that has a continuity setting ?
if not get 2 x 1.5v batteries and an LED and some wire, pull the fuse out and make a simple circuit using all of the above :) little fiddly but easily done
BATTERYBATTERY----LED---FUSE----(BackToBattery)
if the led doesnt light its either the LED is wrong way or the fuse is blown, led lights the fuse is ok
JadeFalcon
Jul 24, 2011, 3:26 PM
Post #5 of 18 (2369 views)
if its a glass fuse you should be able to see the wire inside if its not a glass the use the tip i gave
<span contenteditable="false"><table border=0 cellpadding=0 cellspacing=0 width="100%"><!--reply--><tr><td width="2%"><hr width="100%" noshade size="1" color="#A1A576"></td><td width="10%" align=center><font size=1 face="Verdana,Arial,Helvetica">In&nbsp;Reply&nbsp;To</font></td><td width="87%"><hr width="100%" noshade color="#A1A576" size=1></td></tr></table></span><div style="margin-left: 30px">do you have a multimeter to hand that has a continuity setting ? <br> <br>if not get 2 x 1.5v batteries and an LED and some wire, pull the fuse out and make a simple circuit using all of the above :) little fiddly but easily done <br> <br>BATTERYBATTERY----LED---FUSE----(BackToBattery) <br> <br>if the led doesnt light its either the LED is wrong way or the fuse is blown, led lights the fuse is ok</div><span contenteditable="false"><table border=0 cellpadding=0 cellspacing=0 width="100%"><!--/reply--><tr><td><hr width="100%" noshade size=1 color="#A1A576"></td></tr></table></span>
RobOnMV
Jul 24, 2011, 3:41 PM
Post #6 of 18 (2367 views)
I turned over the set, and found a small door with a hinge clip of some sort. Took that off, and can see a circuit board. It seems to give me access to plugs, but nothing which appears to be a replaceable fuse.
Should I take off the back panel?
btw - it looks like you gave me a link, but it doesn't work.
JadeFalcon
Jul 24, 2011, 3:50 PM
Post #7 of 18 (2362 views)
yes i would take the back off will usually be near when you plug the power cable into the back of the tv...
also the link was not a link it was supposed to be a quote but i think it went wrong somewhere along the line
RobOnMV
Jul 24, 2011, 3:59 PM
Post #8 of 18 (2361 views)
I see what appears to be a fuse about 1/4" away from where the power comes into what I guess is the power supply board. How do you determine if it is blown? Looks fine. It's a white tubular fuse with silver coating on each end. No discoloration seen. It looks like this is something soldered to the board.
JadeFalcon
Jul 24, 2011, 4:29 PM
Post #9 of 18 (2355 views)
usually just pop out with a screwdriver.. will need to come out so you can test it as looking from outside you wont be able to tell if its good or not
RobOnMV
Jul 24, 2011, 4:33 PM
Post #10 of 18 (2353 views)
Is the fuse not the white cylindrical thing, but instead a black rectangular box?
JadeFalcon
Jul 24, 2011, 5:16 PM
Post #11 of 18 (2351 views)
it will either be a white or glass cyclinder just over 1cm long
link below has pictures of them on it and also how to test
http://www.electronicrepairguide.com/how-to-test-a-fuse.html
Jul 24, 2011, 6:21 PM
Post #12 of 18 (2348 views)
The "white cylinder" sounds like a cermic fuse. Sometimes fuses have a lead on each end which is soldered into the board rather than the clip in type. The principle is still the same as far as testing.
RobOnMV
Jul 24, 2011, 8:24 PM
Post #13 of 18 (2346 views)
Thanks - the one in the pic they are testing is exactly what I'm looking at. Guess I'll be getting a tester tomorrow.
JadeFalcon
Jul 24, 2011, 10:29 PM
Post #14 of 18 (2343 views)
build your own just follow my instructions i posted to you earlier :)
RobOnMV
Jul 24, 2011, 11:46 PM
Post #15 of 18 (2340 views)
hat's what that was about! Great stuff - Thanks
Jul 25, 2011, 4:34 PM
Post #16 of 18 (2330 views)
Take fuse out. Pull out any battery operated device (9-volt ones work nicely) and turn it on. Unplug the battery and plug battery back in rotating 90 degrees so that only one terminal is connected. Connect fuse under test to the two remaining terminals. If device runs - fuse good.Wink
RobOnMV
Jul 29, 2011, 2:08 PM
Post #17 of 18 (2322 views)
Re: [jts1957] KDL-37M4000 power surge [In reply to] Can't Post
Can someone tell me the fuse size/ maybe part number so I can order one?
Thanks
RobOnMV
Aug 18, 2011, 11:52 PM
Post #18 of 18 (2257 views)
I checked the fuse - worked fine, replaced the power supply board, still no lights whatsoever. Any guesses what's up?
Thanks
