maverickr
Aug 10, 2006, 1:55 AM
Post #1 of 3
(1055 views)
This konka model 2068U never powered up after a power outtage. I examined it and had to change the voltage regulator, filter capacitor, a resistor, and HOT. All parts were replaced with original part numbers except for the HOT. The original part number of the HOT is D1555. However, I had D1554 on hand and crossed it using NTE quickcross to see that both, D1555 and D1554 used the same replacement. Hence I used the D1554 to replace the damaged HOT. When I power the tv on I could hear it come on but I do not get a raster. Instead I get a constant low tone buzz from the speaker. What could be causing this problem? Thanks for all assistance rendered.
