LCD27V35HA DVD problems
tabee42874
Mar 25, 2010, 1:51 AM
Post #1 of 8 (977 views)
LCD27V35HA DVD problems Can't Post
Hello, I have a VIORE LCD27V35HA. The built in DVD player stopped working. I tried to hook up a DVD player that I know works to it, but it doesn't work. Am I hooking it up wrong? I use a red, white, and yellow end cord to hook it up. Any suggestions?
Mar 25, 2010, 2:13 AM
Post #2 of 8 (975 views)
Re: [tabee42874] LCD27V35HA DVD problems [In reply to] Can't Post
Are you putting the Viore on the SAME input? The ones you are connecting the red, white, yellow to.
tabee42874
Mar 25, 2010, 2:14 AM
Post #3 of 8 (973 views)
Re: [jts1957] LCD27V35HA DVD problems [In reply to] Can't Post
Yes, but I'm not sure which color goes where, but I've tried it all different ways. It just says "source not found"
Mar 25, 2010, 2:18 AM
Post #4 of 8 (972 views)
If you plug the red into the red, white into the white and yellow into the yellow of the set of jacks labeled, let's say "A/V2," AND you manually switch the set to "A/V2," screen says "source not found?"
tabee42874
Mar 25, 2010, 2:20 AM
Post #5 of 8 (970 views)
Yes.
Mar 25, 2010, 2:22 AM
Post #6 of 8 (968 views)
By the way, the model number is not registering any hits on Google. Are you sure about it? How old is the unit?
tabee42874
Mar 25, 2010, 2:26 AM
Post #7 of 8 (961 views)
I know, I've spent hours upon hours researching this tv... I can't find anything on it either. I got it in May 08. That's the correct model number. Got it off back of tv. The only other numbers on it is TL26D080160 and 08012705972.
tabee42874
Mar 25, 2010, 2:31 AM
Post #8 of 8 (956 views)
I'm sorry I did type the model number wrong! LCD26V37HA
