LG 37LF65
gumpractitioner
Nov 4, 2010, 6:43 PM
Post #1 of 3 (3281 views)
LG 37LF65 Can't Post
Hi, IM NEW TO THE FORUM. I USED TO REPAIR TV,S MANY YEARS AGO (JUST AS VALVES WERE GOING OUT) BUT CHANGED CAREER TO WORK IN THE NHS. COULDN'T BELIEVE IT WHEN I TOOK THE BACK OF MY LG TV DUE THE FAULT LISTED BELOW - WHERE IS EVERYTHING!!!
ANYHOW LOOKED FOR THE OBVIOUS -BLOWN CAPS AND DRY JOINTS (DO YOU STILL GET THESE WITH MODERN TV'S?). THAT WAS IT - I WAS THEN FINISHED. I CAN STILL USE MY DMM AND A WIZZARD WITH MY SOLDERING IRON. ANY HELP WOULD BE APPRECIATED.
I HAVE AN LG 37LF65 TV, AFTER IT HAS BEEN SWITCHED OFF OVER A NIGHT IT TAKES AGES TO SWITCH BACK ON, WITH LOTS OF MESSING ABOUT. WHEN IT EVENTUALLY COMES ON IT THEN WORKS PERFECTLY. HOWEVER IT HAS NOW STOPPED WORKING ALTOGETHER.
THANKS
GLENN
darstr
Nov 4, 2010, 9:56 PM
Post #2 of 3 (3271 views)
Re: [gumpractitioner] LG 37LF65 [In reply to] Can't Post
Crazy Check your stand by voltages. Should be listed on the power supply. That is a good place to start. And double check your capacitors. Make sure they don't have a bulge. Good luck to you.
Repair man
Nov 6, 2010, 4:35 PM
Post #3 of 3 (3259 views)
Hello Glenn -- Yes these TVs still have the same issues as older TVs.
The problem you are having sounds like capacitors changing value in the power supply. If they are not vented or bulged on top, like 'darstr' mentioned in the last response, they can still go bad without any physical signs of damage.
Do not keep using the set until you have changed the caps or you may damage more components such as diodes, power transistors etc. I see this every day at the shop (it keeps me in business) where people let it go until the set does not turn on any more then they decide to have it repaired (costly mistake). When caps go bad enough to a point where the set will not turn on they've usually shorted internally at that point and when they short it often takes out the other parts mentioned above.
The caps you need to look for will be high value caps (1000 -uf, 3500 uf or sometimes higher) and you have to pay attention to there physical size/dimensions too sometimes as well if they are in a tight spot.
One big change with today's sets, as compared to when you worked on them last, is that you need to use exact value of caps because the new power supplies are designed so that the ESR value of the caps play a major role (in older sets you could get away with caps of close value).
The caps you need to be concerned with will be in the secondary power supply (caps past the main transformer; opposite end of where the power cord connects).
If you are not sure which caps then take a picture of the power supply and email it to me and I'll point them out for you. You can find my email address by clicking on my profile user-name. -- Dan
Learn Plasma TV Repair
_________________
Learn LCD TV Repair
