richpart
Mar 8, 2011, 1:16 AM
Post #3 of 8
(17817 views)
From Service Bulletin#: 0IVL20080317 Symptom There is a delay when the TV is turning on. Models Applicable serial from 802MX~ to 804MX~ (manufactured before june 9, 2008). 26LC7D-UK, 26LC7DC-UK, 32LB9D-UJ, 32LC4D-UJ, 32LC7D-UK, 32LC7DC-UK, 37LB5DF-UL, 37LC7D-UK, 42LB5DF-UL, 42LC4D-UJ, 42LC7D-UK, 47LB5DF-UL, 47LC7DF-UK, 52LB5DF-UL. Solution The software of TV has to be updated. Update the firmware using a USB flash drive. For warranty work, you have to write this service bulletin number “0IVL20080317” in the remark or description cell. Update Instructions 1) Copy the firmware to a USB flash drive in a folder named “LG_DTV”. Only copy the file for the model you are currently updating. For -> 52LB5DF-UL 47LC7DF-UK 47LB5DF-UL 42LB5DF-UL 37LB5DF-UL File name: Chicago07-MERGE-LU-FHD128-v0311.epk For -> 26LC7D-UK 26LC7DC-UK 32LC7D-UK 32LC7DC-UK 37LC7D-UK 42LC7D-UK 32LC4D-UJ 42LC4D-UJ File name: Chicago07-MERGE-LU-WXGA64-v0320.epk For -> 32LB9D-UJ File name: Chicago07-MERGE-LU-WXGA128-v0306.epk 2) Turn on the TV and insert the USB drive into the TV. 3) If the firmware is newer than what is already installed, the upgrade menu should open automatically. If the update menu doesn’t open, press MENU on the remote and select OPTION. Now press the 7 key 7 times and the upgrade menu will open. 4) Select START and press ENTER on the remote to start the software upgrade. 5) The TV will copy the update from the drive and then install it. Do not turn the TV off until it is finished. 6) The TV will automatically turn off and back on after the upgrade is successfully finished. You can now remove the flash drive and use the TV. To check the current firmware version, press the instart button on a service remote control. Knowlege is King Baby!!!
