corndoggydog
Aug 1, 2018, 4:24 AM
(1321 views)
I have an LG 47LN5400 that is having a backlight issue. Originally the TV would flash when turned on. I tested all the strips and found one that was out. A new strip was replaced and lights up fine when I apply 24 volts to the led strip (all do). Still not getting backlight. Tested connector to main board and all voltages are good. Tested bridge rectifiers and getting about 160 VDC, so that's good. Testing connector to backlight inverter and getting 16 VDC on 2 pins labeled -LED and 78 VDC on the other two labeled +LED. When I unplug the connector I get 76 VDC and 160 VDC respectively on the pins. Any Ideas??????
(This post was edited by corndoggydog on Aug 3, 2018, 6:22 AM)
