maverickr
Mar 23, 2009, 8:37 PM
(1436 views)
Re: [maverickr] Magnavox 27MS343S
For the benefit of others with this set, I was able to solve the problem in the vertical section. It turned out that R307 had apparently opened up when the vertical deflection IC was shorted. I replaced R307 and set powers on fine. However, one little problem still exists. The child lock is activated! From reading i realise that an original remote for this set is needed in order to disable it. So i'm in search of one.
