Auburn Boy
Mar 18, 2018, 1:24 AM
Post #31 of 37
(2263 views)
Re: [jts1957] Mitsubishi CS27201 repair
The blocking diode D500 Where? I can see both (D500/D501) in parts list, but can only find D501 on schematic. voltage at pin 5 of T551 and find 5.78v there. A/CV - DCV - RMS? and how will you know if is good or bad? ( I'm thinking since everything on CRT seems overdriven, there is way too much current being drawn through the main P.S. but not enough to blow the fuse or the load resistor..,) Unplug CRT Board being sure nothing can short. Measure the three RGB Color Output Collectors and see if voltages become higher and resistor runs cooler. Hello again, I unplugged the CRT board from the tube neck and propped it up to safely measure the voltages. I am measuring everything in DC V for now. The voltages on Q250, Q251, Q651, Q653, Q652, Q654, Q656, and Q655 are all the same as when the CRT Board is plugged in. R957 still seems overheated. Key voltages at the collectors of the color output are still: R = 71.4, G = 63.4, and B = 64.6.., Q250 checks out in perfect shape tested on my ESR tester when removed from the PCB. Are there any resistance checks that can be done for the CRT tube itself? Thanks,
