FPSCOMPUTER
Jan 7, 2018, 6:37 AM
Post #1 of 3
(1224 views)
Mitsubishi LT-46164
Hello to all, <br>I have a Mitsubishi LT-46164 that I "BRICKED". I installed a new main board yesterday and in the process I put a USB Thumb Drive in the Wi-Fi USB slot not paying attention. Turned on the TV and received a message that "No Files Found". I turned the set off and put the Wi-Fi USB in the slot. Turned on the TV and now I get the same message at the bottom of the screen no matter what I do. I tried to reinstall the firmware after resetting back to factory spec and still same issue. Can anyone tell me the location of the cmos chip that holds the firmware? I can remove the chip and reprogram it if I can locate the chip. The board number is 934C374002 and the schematic file:vlp43.pdf. <br> I appreciate any help you can give me. I only work on PC's so I am at a loss on this repair. <br> <br>Happy New Year, <br>Phil Gibson <br>FPSCOMPUTER LLC <br> <br>
(This post was edited by FPSCOMPUTER on Jan 13, 2018, 2:35 AM)
