No Red
thetailwind
Feb 2, 2008, 2:17 AM
Post #1 of 10 (1583 views)
No Red Can't Post
I have an RCA proscan. It has no red now. Before it went totally out, it would flicker red and then no red(as part as the picture RBG). Any show I watch only has Blue and Green. Sometimes the red will come back in. When the red would go in and out, it was a quick series of flickers of red and no red. The sound would also hiss and pop when this happens. What do you think the problem is?
thetailwind
Feb 3, 2008, 7:57 AM
Post #2 of 10 (1575 views)
Re: [thetailwind] No Red [In reply to] Can't Post
Someone Has to know. Bump
cademan
Feb 3, 2008, 10:56 AM
Post #3 of 10 (1572 views)
Don't quote me on this but I'm just trying to give you some friendly advice and be helpful. I've never seen your TV or the schematic but I would be willing to bet it would be the red transistor on the little circuit board that plugs into the picture tube. And possibly the associated resistor. On my TV, the red, green and blue transistors are the same part number.
thetailwind
Feb 3, 2008, 4:39 PM
Post #4 of 10 (1568 views)
Re: [cademan] No Red [In reply to] Can't Post
Do you think they need to be replaced or resoldered? For a while I had red but it would just go our occasionally. Now it is our and it comes in occasionally.
shadetree
Feb 3, 2008, 8:28 PM
Post #5 of 10 (1564 views)
we need to know if this is a projection or a regular picture tube tv we need the model no. and ctc no. before we can help
thetailwind
Feb 4, 2008, 12:15 AM
Post #6 of 10 (1557 views)
Re: [shadetree] No Red [In reply to] Can't Post
It is a tube.
Model Number PS34190
RCA ProScan
shadetree
Feb 4, 2008, 3:19 AM
Post #7 of 10 (1549 views)
make sure the module on back of the picture tube is plugged in good and ck it for bad solder connections
thetailwind
Feb 4, 2008, 5:57 AM
Post #8 of 10 (1546 views)
Do you know a link to proper discharge techniques that are clear to new people so that I don't die while doing this. Also, what is a reliable ground that can be found in a room?
shadetree
Feb 4, 2008, 4:54 PM
Post #9 of 10 (1540 views)
as long as the tv is unpluged and you don't mess with the anode plug which is nowhere near the picture tube module you have nothing to worry about however if you are unsure it would be best to call a repair service
thetailwind
Feb 5, 2008, 12:47 AM
Post #10 of 10 (1533 views)
Sounds good. I will wear rubber gloves anyway. I am a big DIY person because I have no $$. I have not died so far or even been injured further than bloody knuckles. So I don't plan to stop now.
(This post was edited by thetailwind on Feb 5, 2008, 6:21 AM)
