mansal48
Oct 20, 2008, 6:13 AM
Post #1 of 5
(2844 views)
PHILIPS, 24RF50S141
Philips direct view tv, plug in and a high intermittent squeal begins. There are no function controls for power button on/off status. The tv begins to make this noise as soon as it is plugged in. I already changed the flyback transformer, same symptom. Problem must be in the P.S because the high voltage does not come on. The crt does not come on. I shoud have noticed that before replacing the flyback. So, it must be a cap, resistor, diode, or H.o.t in the power supply. I can't find a schematic for this unit yet. Does anyone, have location numbers and component values for this circuit fault of the possible culprit. (diodes...etc.,zener..) Thanks
