Nov 28, 2005, 12:12 AM
(1627 views)
Re: [Ronzoni007] PHILLIPS Blown fuse
Philips flybacks are usually pretty reliable so I would more suspect that the horizontal output transistor (HOT) is shorted or the problem is in the primary power supply. In circuit, you will see a very low resistance between the emitter and base of the HOT and a front to back ratio resistance between the collector and base and emitter and base. If the HOT is good, I would look for a short in the promary power supply.
