Larry E
Sep 12, 2006, 12:16 AM
(1570 views)
C4108 is in the power supply, the other 2 I have never heard of, are you sure it`s not 4101 & 4104?what is the part you ordered? Thomson uses a 4 digit part number but marks the circuit board with the first number deleted??? Don`t ask me why, I`ve never figured that one out either, if you look at the right edge of the main board, 1/2 way up there is a 16 pin IC, U14101, C108 is located right next to the IC, if this cap goes bad (which it does quite often) the set won`t start, it`s a good idea to replace 102 & 104 at the same time, tell us what the part is you already purchased (40431-090) and we`ll know better what you have for a failure, if Thomson says you need to replace the caps it`s a good idea to listen as they are a common failure item or they wouldn`t have told you to replace them, Larry E
