Oct 15, 2005, 8:50 PM
Post #2 of 5
(1356 views)
Re: [gio25] Panasonic CT-27G7DF problem
Yes. It is fairly common for the vertical output IC to fail.but first, I wold check for 26 volts on pin 6 of the IC (probably IC451). If that is missing, I have seen occasions where the fusible resistor in the 26 volt power supply opened and the was the only problem.
