Panasonic PT-51G44A
imbassman
Aug 6, 2006, 8:01 PM
Post #1 of 6 (2639 views)
Panasonic PT-51G44A Can't Post
My Next door Neighbor Gave me a Panasonic TV model PT-51G44A.
1. Where is the best place to get a service manual.
2. The plastic screen has something on it. Looks like something was set on top of tv and spilled on. Mainly dots. What is the best cleaning method.
3. The picture is a little dark. I did adjust the brightness that help But I believe it may be a bigger problem starting.
4. the biggest problem is the picture changes. looks like it zooms in and out. OR it will flicker. Mostly on the horizontal plane. This happens when the the camera angle changes and at the beginning of a commercial(then it settles down). It is more pronounced if there is a great amount white in the picture or a great amount text.
Thank you in advance for any direction. (yes I am a technician but have not done much TV repair)
Aug 6, 2006, 8:11 PM
Post #2 of 6 (2636 views)
Re: [imbassman] Panasonic PT-51G44A [In reply to] Can't Post
clean the screen with a damp cloth. the screen jumps sizes probably because you have it set on auto format. switch it to panoramic or 16:9 whatever its called and this should stop the size changing.
(This post was edited by techchris on Aug 6, 2006, 8:11 PM)
imbassman
Aug 6, 2006, 8:18 PM
Post #3 of 6 (2633 views)
Re: [techchris] Panasonic PT-51G44A [In reply to] Can't Post
Thanks for the information. Does not look as if I can change the aspect Ratio. I am looking for the owners manual now to double check.
Paulpablo
Aug 6, 2006, 10:30 PM
Post #4 of 6 (2630 views)
Sounds as if you have multiple problems, and you hauled off your neighbor's garbage!
imbassman
Aug 6, 2006, 11:45 PM
Post #5 of 6 (2624 views)
Re: [Paulpablo] Panasonic PT-51G44A [In reply to] Can't Post
Why is it people cannot be constructive. No I did not haul it off my neighbor's garbage. They asked if I may want it and try to fix it. This way it does not end up in a landfill screwing up the enviornment. As you can see my first question was where might i get a service manual. Not withstanding a cost factor just because there may be more than one problem does not make it unfixable. Tongue
docdave
Aug 11, 2006, 12:00 AM
Post #6 of 6 (2611 views)
hey good for you. i looked for your print don't have it . try calling a place called tritronics for your print or ask them for help getting one ps MY BUDDY IN A NOTHER SHOP IS A PAN WARRENTY DEALER WHO CALLS ME ALL THE TIME FOR HELP DROP ME AN EMAIL
I"LL SEE WHAT I CAN DO
DOC
