bbrtv
Oct 13, 2006, 5:54 PM
Post #4 of 5
(890 views)
Replacing tube is out of the question unless you can get a 2nd hand one.New one would be as expensive as a new tv.Usually the crt is not the prob.A complete crt failure is not all that common.Usually see changes in colour or gets dim.Now you are at the point that some troubleshooting is needed.Obviously the tv still has power,but what actually happened is a good question.If they want $80 to look at it you can bet repair will probably be over $100.May not be worth it.
