jmjosse
Dec 15, 2021, 2:03 PM
(877 views)
Panasonic Tx-65x700 starnge starting behavior
Hi everybody I have a problem with a Panasonic FX-65x700. When left off for more tan 10 minutes, when we start it we have, and always like that - backlight on, no display, black screen - we switch it off and on again - we have alternate black vertidal bars and colored lines, always the same patern - switch again and it works, stable ;If we stitch if off and on again, its ok as long as we don't leave it off for 10 minutes. https://youtu.be/WmgrGgEntKc Switch on, off, again at 1 min you'll see the patern. What I'ev done so far - open the tv, check for visible defetcs on each boards, check cables etc... - resolder some bad looking soldering on the power board - suspecting a temperature sensitive issue (aka, when it's hot it works ?), but one can exclude this issue on the main board. What can I do next to try to isolate the responsible of the problem? T-Con failure ? Many thanks for advices and help JM
(This post was edited by jmjosse on Dec 16, 2021, 12:15 AM)
