daveyhouse
Apr 16, 2007, 6:40 AM
Post #1 of 5
(1060 views)
PT-51HX41E / CHASSIS AP820 I recently took the guns out disassembled, cleaned with alcohol and refilled with new coolant. While the unit was apart, I took the chassis out and blew off all the dust with air compressor. When I reassembled the unit I was getting a zapping sound from the flyback and it was interfering with the picture with like noise on the edges of bright areas. After a little research I discovered that dust can cause this with the right amount of moisture. I took a closer look then saw that some dust balls joined around what looks like a fret with a heatsink attached right next to the flyback txfr. I took a Q-tip wet with alcohol and removed the dust. Now when the tv is turned on I get a lite popping sound from the flyback. With this popping sound the the green and blue pic size is expanding then snaps back to where it is supposed to be. The brighter the color the faster the snaps are. As I turn down the brightness and contrast the snaps happen at a slower pace. The red also affect the speed of the snapping but does not expand like the others? Thanks in advance, Dave Attached is link to a video of it. http://s100.photobucket.com/albums/m6/daveyhouse/tv2/?action=view¤t=102_0875.flv
